The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526вопросов Показать все
Galaxy s4 Digitizer is Touching LCD
Hi,
I just replaced the digitizer on my S4 and after a few hours I can see a bubble being created because it is touching the LCD.
During the install I used 3m double sided tape to make a border. Should I double up the tape?
Thanks Everyone
Это хороший вопрос?
Оценка -1
Добавить комментарий
5 Ответов
Выбранное решение
yes you should and if that doesnt help triple it
Был ли этот ответ полезен?
Оценка 1
Its easy to damage your Galaxy S4 while trying to repair it yourself. I sent mine for repair and they do a great job. They fixed my S3 and my S4 and I could'nt be happier with the price and service they gave me!
Thank you ifixit.com for leading me in the right direction for my repairs! This site ROCKS!!!
Оценка 0
I always put one row of 2mm tape on the lcd face along the bottom, top and sides to form a dust proof barrier. I had same problem with adhesive tape they sell for the phone. Since I started doing it this way I have not had the "Newton ring" you speak of. This can also be solved by using loca to reassemble. The s4 seems to have a tighter tolerance than the s3.
Оценка 0
Hello my digitizer needs fixed also does anyone know where I can get it fixed n how much.. didnt hav my samsung galaxy s4 active long either
Оценка 0
The only true way to fix this is to use Liquid Optically Clear Adhesive Or LOCA and that will ensure that there is no air gap to allow the top glass to touch the lcd/digitizer on your Galaxy S4. Even if you double up the tape, eventually the tape will get so smashed down and then glass will start to bow that the glass will touch the lcd again. Not guaranteeing that will happen but most certainly can.
Here is a video of a tech applying liquid optically clear adhesive / LOCA to an S4 LCD.
Оценка 0
Добавьте свой ответ
Manny будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 9,280
