Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
Battery not charging, firm green light on AC adapter
My MBP is about 4 years old, and the old battery had a cycle count of 1000+ so I bought a replacement last week and replaced it myself. Everything worked great (patted myself on the shoulder) until a few days ago I noticed it wasn't charging. The green LED indicator is on so I think the Magsafe isn't broken.
I've tried resetting the SMC & PRAM (or I think I did) but no luck. Not sure what my other options are but I think I'm going to try wipe the connectors with alcohol & cotton swab next.
Here is the info on my batts / AC:
Battery Information:
Model Information:
Serial Number: 9G925P26G4M0A
Manufacturer: PS
Device name: CL5322
Pack Lot Code: 4274
PCB Lot Code: 0b05
Firmware Version: 0000
Hardware Revision: 0000
Cell Revision: 0000
Charge Information:
Charge remaining (mAh): 0
Fully charged: No
Charging: No
Full charge capacity (mAh): 3944
Health Information:
Cycle count: 3
Condition: Normal
Battery Installed: Yes
Amperage (mA): -2626
Voltage (mV): 11069
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 60
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 15
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
Battery Power:
System Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 2
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x00bb5bdf
Charging: No
Would it be safe to assume it's the DC in board or logic board that's causing this?
Thanks in advance!!
Это хороший вопрос?
Счет 0
1 Комментарий
I also replaced the RAM & hard drive if that could have anything to do with it
из
Добавить комментарий
4 Ответов
Выбранное решение
Not necessarily - I have know new Chinese batteries to fail straight out of the box... If you can try the battery in another laptop - if that also fails to charge Contact your vendor about this.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Oh I see. But if istat and coconut battery are both saying my battery health is good (or at least normal), it could still be faulty?
All of the sudden now it is saying that it's charged, but as soon as I unplugged the AC Adapter, the MBP dies. It seems like it refuses to use power source from battery.
Unfortunately I don't have another MBP to test out the battery / charger, and I am not under warranty anymore.
из
Yes - these batteries are smarter than most - there's a mini computer built into them it monitors and controls charging because there's a real danger of fire if they malfunction.
из
As Machead explained the the battery pack has a computer within it to monitor and control the charge. I would recommend resetting the SMC which should clear out any incorrect values Apple TN on reseting the SMC. That should fix things if the battery pack is good.
Счет 2
1 Комментарий:
Resetting the SMC fixed the problem with my wife's 2010 MBP. Thanks!!
из
  Connected: Yes
  Wattage (W): 45
  Family: 0x00ba
  Serial Number: 0x001fe745
  Charging: No
Счет 0
Model Information:
  Serial Number: C0144360E2GF90LAL
  Manufacturer: DP
  Device Name: bq20z451
  Pack Lot Code: 0
  PCB Lot Code: 0
  Firmware Version: 511
  Hardware Revision: 000a
  Cell Revision: 1210
  Charge Information:
  Charge Remaining (mAh): 5387
  Fully Charged: No
  Charging: No
  Full Charge Capacity (mAh): 6287
  Health Information:
  Cycle Count: 215
  Condition: Replace Now
  Amperage (mA): 0
  Voltage (mV): 8190
Счет 0
Добавьте свой ответ
Robin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 40
За всё время: 20,316
