Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586вопросов Показать все
iFixit optical drive replacement cable compatible with 6Gb/s?
Product code: IF161-040-1
Apple Part #: 922-9032
I had a 3Gb/s disk on this bay. The disk became defective, having developed several bad blocks, and I bought a Seagate SSHD 1TB disk, which is a 6Gb/s part. The bad blocks are genuine, I tested the disk on external enclosures and it's really defective.
Now I am having I/O errors on my secondary disk, which is 6Gb/s. I was not having them previously, so I think the cable either is defective, or the MacBook Pro either has some software or hardware problem.
The software reports a 6Gb/s connection and a 6Gb/s negotiated link speed. Maybe there is something amiss on the software though, the I/O errors develops randomly while using the computer, and it loses the disk until next reboot.
On the hardware side, it could be:
1) a damaged connector (best case), replacing it would fix the problem IF the part is 6Gb/s compliant.
2) a hardware design issue (very bad, unsolvable) where the Mac is unable to supply enough energy to the disk, or has some signaling problem with 6Gb/s at the second bay, even if it initially negotiates the correct link speed.
3) a hardware defect (very bad) which needs logic board replacement.
I am looking for insight if 1) is a viable option: is the iFixit part compliant with 6Gb/s link speed?
I don't want to spend in a part which will not solve my problem.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
I vote for choice #2 - I don't think that the throughput/bus speed of the optical bay is equal to that of the HD.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
As I stated, the System Information app reports this bus as a 6Gb/s, and when paired with a 6Gb/s disk it successfully negotiates the maximum link speed. So, at least on the chipset level your conjecture is not correct. It may be the case that a hardware defect or design problem is preventing it from operating correctly though...
из
Добавьте свой ответ
Brazilian Joe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 445
