Epson Printer NX510 Error message: "A printer error has occurred..."
I got this error message when I turned my printer on: "A printer error has occured. Turn off the printer, then press On button to turn On. See your documentation".
I did take a look and they say to verify there is no paper jam, which is the case here and then to call the Epson support centre, what I did.
The answer I got from the guy I spoke to is to send it to an authorized repair centre as there is nothing he could do over the phone. It seems it is a mechanical problem, but I wondered how much the repair will cost (probably more than what I paid for the printer...), so the technician offered me a big $30 discount to buy a new printer on their website...
Did someone get the same problem and fixed it? If yes could you please tell me what you did?
Many thanks in advance
Это хороший вопрос?
19 Комментариев
this is gone case printer please do no buy it. i could not use it as new one.its laying with me. even cant resale it.
из Arjun Singh
Thank you Bobby, problem solved.
Also when I moved the cartridge housing there was a bit of paper stuck underneath from an earlier paper jam.
Cheers Steve.
из stevemooney
Thanks from me too, it works for the NX515. I also noticed that the cartridge housing was not all the way to the right, just a click off. As mentioned earlier Epson support advised to send it back to be fixed instead of telling me what Bobby already knows
из Ernie Sanz
Big thanks from me also! Worked perfectly!
из m.anne
I have an Epson WP-4540. This didn't work for me. It is also printing tons of yellow ink. I was trying a solution to that when it gave me this error message.
из Pam Kidd
Показать 14 больше комментариев
