The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73вопросов Показать все
I dropped my phone in water
i fell into my pool yesterday and i had my z10 in my pocket. i set it in rice and took out the battery and the next day i tryed putting the battery back in and the red light wont go and it wont start help me please i cant get another one
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Выбранное решение
jaden myers, disassemble your phone. take a look at this teardown to see if you are up for it. Once it is disassembled, clean every part with 90%+ isopropyl alcohol. This includes every connector and cable. Check for any burned or missing component. You can use a soft brush, just be careful that you do not knock -off any component. Once cleaned replace the battery, reassemble and re-evaluate for any damage. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
Some shops offer to give your smartphones a deoxidizer bath. This worked in my family with an iPhone incidentally dropped in a bath. Try it fast before it's too late. Keep your phone in a rice bag before it to try and aspirate the remaining water.
Оценка 1
hi today my phone [blackberry z10] fell into the toilet and it turns on its just that the screen doesn't work what I mean is that when I try to get into my phone it wont let me...when I touch the screen it doesn't do anything....I don't know what to do someone please help thankyouu.
Оценка 0
Добавьте свой ответ
jaden myers будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 4,427
