Is it the video card?
Boots up ok, perfect display. After 5 to 10 minutes screen develops a whole screen-full of 'sparklies' and unable to get response from keyboard or mouse. Power supply checks out ok. I'm guessing that this is a thermal-related issue of a component somewhere on the video/graphics card?
Это хороший вопрос?
8 Комментариев
Try connecting an external monitor to your system to see if it shows up on the external if it does you nailed it as being aGPU problem, if not then the LCD or the LVDS cable has an issue.
из Dan
Thanks to Dan. Living on the Greek island of Skopelos restricts your economic choices
из Alastair
Dan is spot on with the video card comment, however I've also seen these symptoms occur with logic board failures as well.
из LikeARabbit
Alastair, we understand your difficulty, but can you connect it to an external monitor?
из oldturkey03
I spent some time on holiday in Skathos when I was much younger. Do you ever get a chance to go over to Peristera? I think thats the island that Pythagoras helped in creating a aqueduct tunnel though a large hill for a village.
из Dan
Показать 3 больше комментариев
