Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20001вопросов Показать все
Swap 2012 Logic Board For 2011
Basically I've bought a 2012 logic board on ebay for a bargain and its a way higher spec than the macbook pro i previously fixed.
Anyway according to ifixit guides and wikipedia basically besides the logic boards, the 2011 and 2012 a1286 models are no different components wise.
So therefore can I buy a 2011 macbook pro thats broken and put it in? Reason being is on ebay they are significantly cheaper.
Это хороший вопрос?
Оценка 0
1 Комментарий
Edward please do not post the same question multiple times. The answers will not change.
из
Добавить комментарий
1 ответ
Выбранное решение
If you have a board from a retina machine it must go back into a retina machine - it can not go into a non retina machine. Likewise a retina machine can not be driven by a nonretina board.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
It isn't ,you can get that spec on a non retina 2012 model
из
If you knew the answer why did you ask for help 3 separate times? When you ask a question sometimes the answer is not the one you want to hear, but repeated asking will not change facts.
из
No need to be rude. There are minor changes despite the near identical logic board. There are a few differences with stand offs etc
из
Добавьте свой ответ
Edward будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 525
