SSD Upgrade possible on this old model?
Hello,
Thanks for your fantastic work @ifixit.com !
Is there any way to replace the PATA harddisc to any SSD on this old model of powerbook 12" ?
Thanks a lot,
Kind regards,
Gregor
Это хороший вопрос?
Hello,
Thanks a lot,
Kind regards,
Gregor
Это хороший вопрос?
Gregor - I don't think you want to go down this path with this older system.
First, Yes, you can still find some older SSD's that have a PATA interface (used). So you could do that. The rub here is these are old tech and are on the small size so you will be limiting your system and have very little space to work with.
As to the OS you are using on this older system (OS-9 or older OS-X) does not have TRIM support so it will wear the SSD more quickly.
Given all of this it's still better replacing the HD with another one if your HD is going Vs a SSD.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 261
