My Screen show some vertical lines
in a particular area it always shows vertical green lines.
Это хороший вопрос?
Это хороший вопрос?
Anoop, it would help if you would post an image with you question. From your description, it does sound like a TAB error and can only be fixed with very special (and expensive, tools. If it is a tab error, the best fix would be a replacement.
Был ли этот ответ полезен?
It can either be a hardware of software problem, lets check it one by one. First try to download the updated driver from your machine`s manufacturer`s website then install it. If the problem still persist then its defiantly the hardware level problem which is caused by faulty LCD cable of r joint so you can further take it to some hardware shop.
За последние 24 час(ов): 1
За последние 7 дней: 7
За последние 30 дней: 14
За всё время: 785
