adapting a Chi Mei LCD?
Hello
Is it possible to install an N154C6 LCD panel where the original was an Optronics B154PW04 v.4, by also changing the video data cable ?
As far as I understand your writing (see Note in MacBook Pro 15" (Models A1226/A1260) LCD Panel) it's just a problem of connector location. Or are there other issues (e.g. electrical) ?
Thank you
Это хороший вопрос?
TRAN, N154C6 which version? there are numerous out as well. I recommend to look at the datasheet for both of the panels and compare it that way.
из oldturkey03
Hi Machead3,
it's N154C6-L01
Thanks
из TTR78
just checked both datasheets and it does appear as if the electrical difference are to minute to make a big difference. The connector is the same but the location is different. If nothing else, give it a try and see ....hope this helps.
из oldturkey03
