Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73вопросов Показать все
Camera Shutter Stuck After Screen Replacement
I recently replaced a broken screen and now the back camera shutter is stuck. I tried a new back camera, but that didn't fix it. I also tried a hard reset, but that also didn't work. Ay ideas how to resolve the issue? Could the connection not be right?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
I figured it out. I removed the camera, erased and reset the iPad, ran the set up process, and then reinstalled the camera. Then everything worked.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Some loose connectors between cameras and the logic board. Reseat every connector in between, especially the front camera which is easy to come off
Оценка 1
Добавьте свой ответ
Boss77 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 9
За всё время: 261
