How to Reset Password?
How do you reset the password? note: i forgot what the password was even after the hint: " ".
Это хороший вопрос?
Это хороший вопрос?
Here are the instructions from Apple on resetting your password. Ralph
Был ли этот ответ полезен?
Turn off the computer. After it is completely shut down hit the power button while holding "command s" Once all the text has loaded tip the following without the "" marks and with the spaces in mind. Also enter is just hitting enter and not typing enter.
1. "sbin/fsck -y" then hit enter
2. "sbin/mount -wu /" then hit enter
3. "cd /var/db/" then hit enter
4. "ls" then hit enter (notice this is a lowercase L)
5. "rm. ./.AppleSetupDone" then hit enter
6. "ls" then hit enter (again a lowercase L)
7. "reboot" then hit enter and wait.
When your mac starts up the next time it will be tricked into thanking its new and make you go through the info process. This will create another admin account. When you log into the account that you have just created you can go to system preferences -> accounts -> then select the account that you forgot the password to and hit change password. Then log into the previous account and delete that account that you just created and walla!!! You now have a password that works.
there needs to be a "/" before the sbin in the first two steps
step two, its "-uw"
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 9
За всё время: 26,566
1 Комментарий
How to recover online?
из Sweta Jain
