Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Small metal ring dropped from logic board.
While following the guide to replace the earpiece speaker, step 19, removing the logic board, a tiny silver ring dropped from somewhere (see image). Have no idea where this goes. Put the phone back together without it. Phone is working well. Should I worry about this ring?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
This is the screw threads piece of the lowest screw on the so called WiFi Plate, plate that covers many connectors at top of iPhone. It is not a necessary part. It is held in place by the Y shaped metal piece and the screw. When you removed the screw it slipped out of place.
The location for this part is below the yellow circled screw:
http://d3nevzfk7ii3be.cloudfront.net/igi...
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Oh how interesting! When I first went through the steps to tear down my iPhone and got to that screw, I wasn't able to unscrew it. It was turning but wouldn't come up, had to take a flat driver and push it under the screw head to remove it. When I put the screw back in, all I had to do was to "drop" it in its hole, no screwing needed. Now it makes sense.
Should I worry that this screw might come out of its hole by itself, or is the free space small enough that it will stay in place?
из
Добавьте свой ответ
Sccoaire будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 287
