replace display with an other model one
Hi!
I have a MBP mid 2010 and a 2011 one.
Can I swap monitors of these Macs ?
Это хороший вопрос?
Hi!
Это хороший вопрос?
You didn't specify which display/laptop you have 13", 15" or 17". The 15" display is the same from 2012 to late 2008.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Sorry, it's the 15''.
So I can do that. I want to change all the topcase not only the LCD.
bmael , the complete display for the 2010 is part number 661-5483. Here is the compatibility for that part number:
MacBook Pro 15.4" 2.0GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.3GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.3GHz Core i7 (A1286) - Mid 2012
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.4GHz Core i5 (A1286) - Mid 2010
MacBook Pro 15.4" 2.4GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Mid 2009
MacBook Pro 15.4" 2.53GHz Core i5 (A1286) - Mid 2010
MacBook Pro 15.4" 2.5GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.66GHz Core 2 Duo (A1286) - Early 2009
MacBook Pro 15.4" 2.66GHz Core 2 Duo (A1286) - Mid 2009
MacBook Pro 15.4" 2.66GHz Core i7 (A1286) - Mid 2010
MacBook Pro 15.4" 2.6GHz Core i7 (A1286) - Mid 2012
MacBook Pro 15.4" 2.7GHz Core i7 (A1286) - Mid 2012
MacBook Pro 15.4" 2.8GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.8GHz Core 2 Duo (A1286) - Mid 2009
MacBook Pro 15.4" 2.8GHz Core i7 (A1286) - Mid 2010
MacBook Pro 15.4" 2.93GHz Core 2 Duo (A1286) - Early 2009
MacBook Pro 15.4" 3.06GHz Core 2 Duo (A1286) - Mid 2009 from here. so it does look like a fit. Hope this helps, good luck.
OK thanks a lot.
I did it !
bmael, good job:)
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 676
4 Комментариев
Would you give us the last three figures of the serial numbers on both machines so we can answer your question.
из mayer
Hi,
Sorry for my poor english ;)
MBP 2010 SN : W804....AGW (i7 2,66MHz DUAL)
MBP 2011 SN : C02F....DMGG (i7 2,3MHz QUAD)
Thanks
из bmael
Nobody knows if it's possible place the 2010 MBP monitor on the 2011 MBP and vice versa ?
из bmael
bmael, does this look like the specs for your computer:"Intro Date: April 13, 2010 Disc Date: February 24, 2011
Order No: MC373LL/A Model No: A1286 (EMC 2353*)
Subfamily: Mid-2010 15" Model ID: MacBookPro6,2
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 500 GB (5400 RPM) Std Optical: 8X DL "SuperDrive""
из oldturkey03
