The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
523вопросов Показать все
Galaxy s4 rear camera replaced now have "camera fail" error
I recently replaced my rear camera on my galaxy s4. After replacing it and re-assembling the phone everything turns on fine. When I try tyo run my camera I get a "camera fail" error and it exits the camera. I assumed it was a bad camera and ordered another. Installed this one same error. I put the older camera back and it works just fine. Anyone have any fixes for this? I have reset the camera app and removed all the cache and I still get the error.
Это хороший вопрос?
Оценка 1
Добавить комментарий
8 Ответов
Наиболее полезный ответ
Samsung galaxy s4 model GT19500
its back camera worked but front camera failed after repairing .
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
i have too this pb plz help
из
I Have the same problem. Tried to factory reset the phone, but still the same problem.
Оценка 1
1 Комментарий:
The origional camera has the following text on it:
jfv06
1313421
fs3416pa
b06520
where the new one has:
fjv06
1306613
fs3314pa
b05090
Both for the GT-I9505
из
I also need help,hit the camera and i get a black screen . I did a factory reset and replaced the camera. could it have something to do with a software update that i did earlier? There has to be a fix out there!
Оценка 1
anybody got this fixed? I have the same issue....
Update
I've been reading around that there are different versions of the camera. I've noticed this too. The IC soldered onthe replacement has a different amount of pins than the original. The original has 5 pins while the replacement has six...does anybody know if that has something to do with it?
Оценка 0
gt
Оценка 0
“Warning: Camera Failed” shows on the Galaxy S4 after replacing the camera. The reason is that you use a wrong S4 camera. watch the video : Why camera app failed after Galaxy S4 I9500 camera repairing
The words typed on the camera flex cable is the key to distinguish the different cameras.
The camera typed “GT-I9505” or “F” on the flex cable is suitable for SCH-I545, SCH-R970, SGH-M919, SPH-L720 and SGH-I337 version. The camera flex cable was typed "GT-I9500", which is only suitable for I9500.
Оценка 0
so may be he has placed the wrong camera for his galaxy s4
Оценка 0
1 Комментарий:
I think so. There are several reasons for "camera failed". It will occur after using a wrong camera.
из
Samsung gt i9505 camera restar probilam
Оценка 0
Добавьте свой ответ
Myles McCluer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 7,342
