Hdmi to dvi on ps3, can u cut the wire and get sound
I understand that dvi Will not carry sound. but if u plug the hdmi in is there sound wires and if so is there anyway to cut into the wire and get to them to put a jack on. I've look online but found no wiring diagrams with wich wires are sound.thanks for any help
Это хороший вопрос?
Оценка -1
1 Комментарий
what are you trying to set up?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
If you're trying to cut an HDMI cable and attach an RCA or 3.5 mm audio jack, no, you cannot do that, as HDMI is digital and those are analog. You can however get something like this and this if you're trying to get analog audio out of hdmi.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
gavin hirst будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 10
За последние 30 дней: 10
За всё время: 198
