How to check whether the display is working or not (Only Display)
Hello all,
My question seems to be confusing, but currently I am in the same state.
Anyways, yesterday due to heavy rainfall, water went inside my MBP from behind (Hinge exhaust vent). And my wife started it to check whether its working or not in my absence, ya sad but true, and the result? of course, it worked for some time and then when we restarted, it was starting but nothing visible on screen.
I taken it to Apple Care but as usual, they asked for my kidney and lungs, I mean 35000 (around 600 USD) for the screen cost as every thing is working when he connected it to external display.
But, he noticed some signs of short circuit over the socket, where the screen display cable connects.
Hence I just want to check, whether the socket is faulty or the display ? so if any, please suggest me the ways of checking whether the display is working or not. so that I will go for the Logic board replacement.
Это хороший вопрос?
Оценка -1
1 Комментарий
Attach an image of " he noticed some signs of short circuit over the socket, where the screen display cable connects." this with your question
из
Добавить комментарий
1 ответ
Выбранное решение
If you're into DIY, or know of a less expensive local shop, simply cleaning the corrosion from the connector may revive it. Also the rest of the board at the back should be checked because corrosion worsens over time.
Check out the threads from "repair water damage" and search "liquid spill" for ideas of how much/complex the DIY revival of wet units can be. You need to start with obtaining the proper tools (every repair job is easier when you use the correct tools).
Of course it's possible that the corroded connector cable shorted out the display, but start with the simplest, cheapest, easiest things and work forward.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
dhanesh shastri будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 841
