Repair guides for the MacBook Air, Apple's current line of consumer laptops.
4656вопросов Показать все
How to move data from my old hard disk to my new one?
I took out my HD from my Mac air, is there anyway to move the data from it onto another computer? I took it out because it had an error code: 4hdd/11/40000000 SATA (0,0).
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
That is a hardware error code, it could be the cable or the drive. Get an external case for your drive (some new/replacement MacBookAir drives can be purchased with an external case for the original drive) If it's not damage to the the dive it will mount (if it mounts you may need a new SATA cable for the MacBookAir). From the New OS install you should be able to use Migration assistant to transfer the files... OR use TimeCapsule to restore from your old backup.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Raymundo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 268
