Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117вопросов Показать все
Airport range has decreased since repair
I recently replaced my iBook G3 clutch hinges and optical drive. Since I've but it back together I seem to have very limited airport range. In fact I pretty much have to be in the same room. Seems like in all likelyhood i've pinched the airport wire, but before I open it back wanted to see if there were any other suggestions...
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Looking at the repair guides I believe you are correct in your assumption. I would open it up and check the airport antenna cable. Ralph
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
it was pinched. problem solved!
из
+ Excellent
из
voted to accept anwser
из
Наиболее полезный ответ
most likely i would say that you pinched the cable (sorry - sounds totally stupid to repeat you - but thats what i would think)
Оценка 1
Добавьте свой ответ
Flynn Stewart будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 853
