Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Can I add a SSD drive myself?
Hi!
Sorry, I'm new on, this site, I hope the question hasn't been answered already.
First: I'd like to have confirmation that I can buy this new iMac with the standard RAM can I easily max it out to 32GB myself later?
Second: I don't understand what "PCIe flash SSD available" means. Can I add a extra SSD drive myself?
Thanks to those who help!!
Это хороший вопрос?
Счет 7
1 Комментарий
Any updates?
из
Добавить комментарий
3 Ответов
Выбранное решение
Sort of - EveryMac says: This model has a proprietary PCIe connector for an SSD. If the SSD is not installed at the time of purchase, the connector still is present and later professional or self-installation is possible.
The problem may be in locating a "generic" version of this proprietary drive. OWC has been among the first to offer solutions for previous Apple Proprietary drives. It's not clear to me if they have done so as yet for the iMac.
The RAM should not present a problem.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Счет 6
After a lot of research this looks like a viable option: SSD Adaptor
Waiting on a response from them for compatibility with the Late 2013 iMac's. This should work as they have made very little changes to the logic board, however if examined closely the shielding on the pcie connector is sligthly different with a cut on the top (2012) model compared to a non cut shield on the 2013. I have ordered the kit regardless, and I will confirm everything once the kit and adhesive strips are in hand.
The only down side that I can see at this point is that power is sourced from the primary HD and is split (supplied splitter with kit) to accommodate the SSD addon. I will also take the time to do a video walkthrough, as it is sorely needed.
Update
Update: All SSD Blade Kits designed for 2012 models are not compatible with the 2013 models!
The following link can shed some light on this problem: HERE
What can be done now?
My suggestion for now is a part pulled from late 2013 MacBook Pro's or iMacs will work for the SSD option, with a Homebrew Fusion setup a few terminal commands away. I would highly suggest skipping over ANY 128GB SSD modules as they are considerably slower than the 256GB modules. Please be aware that 2012-Early 2013 modules are not the same as Late 2013! The retaining pin (off center recess on the SSD module) on older modules are 1-2mm right of where the new retention resides. The contacts and number of pins are also different. Also as a side note a 256GB Samsung 840 Pro registered 38MB's write with a 130MB read rating through BlackMagic, using the normal SATA connection to the stock drive! I have a 15 day timeframe before my Samsung 256 SSD designed for the PCIe is delivered, at that time i can do further testing and provide a guide if necessary. A full guide can be done once a blade kit is finalized for this model.
Apple has indeed made it extremely difficult, but the war is not over!
I will be actively involved in getting more information from OWC and a possible fix through microsatacables for a revision on their 2012 SSD Blade Kit. (microsatacables.com also provided the blade kit for this test, many thanks to them for their overwhelming support for the modding community!) What you can do is contact OWC, tell them to provide us Late 2013 SSD modules for the PCIe.
I'll add to this once more information is available. You do still have the option of using a thunderbolt driven external drive, but the cost is still pretty high.
Счет 2
7 Комментариев:
Have you asked the supply of this adapter if they have tested it in the newer '13 model? Also have they truly setup a dual SSD setup with this adapter? I have a feeling they have only setup their SSD setup with the stock iMac with a HD (not SSD) in the HD SATA mount.
из
I should point out the M2 PCIe mount is in the process of being standardized as soon as it is I think you'll find a few suppliers will offer SSD devices that will work here. In any case I'm sure other options will be offered by people like OWC if the M2 standard is not compliant in how Apple has done things.
из
Still waiting on a response from the supplier. Regardless I'm willing to do the groundwork and testing using the blade adaptor. Tested on 2013 models: waiting on response, Dual SSD: I can test that as well using either the OWC 6G or Samsung 840 Pro's, raid 0 ability would need to be confirmed. I will be testing on a late 2013 27" with the 1TB only drive option. I'll be updating the 1TB to a 3TB WD Red and adding a Samsung 840 Pro 256GB SSD through the vacant pcie using the blade kit. As I would obviously prefer a direct connect solution, this unfortunately is something that should work as intended without the wait for perfect solutions. OWC is a year out before they will have their product available, apparently not a priority to them. I look forward to getting everything in, I'm just waiting on your adhesive strips to arrive before starting the job.
из
I will love to see what you come up with, please think about posting an IFIXIT guide with your work. I'm sure others will want to dive in once someone has blazed the path with a good guide. Besides, you did want to be an author didn't you? ;-}
из
Yes, I have started the guide, including the parts required and detailing the models that this can and cannot be performed on. I'm always thorough regardless, so I will also make available a printable and mobile guide on one of my sites as well. I'm very curious to see the performance aspects of the split drive setup and utilizing a homebrew fusion setup with a much more reliable and faster spinning drive and SSD. I can add all the terminal commands if needed as well for the fusion setup. One note, if possible please add a note to the adhesive kit, to be used on 2012-13 models. I understand the similarity but it does come off as somewhat confusing when ordering here.
из
Показать ещё 2 комментариев
I just purchased an iMac 27" (late 2013) with the following specs:
3.2GHz quad-core Intel Core i5
Turbo Boost up to 3.6GHz
8GB (two 4GB) memory
1TB hard drive1
NVIDIA GeForce GT 755M with 1GB video memory
It's the latest low end model that Apple is currently selling.
If you have the same model then you can upgrade the 1TB hard drive with an SSD just like you can in any other computer.
I just finished installing 32GB of RAM from OWC http://www.amazon.com/gp/product/B00IELD...
and a 1TB Samsung 850 Prohttp://www.amazon.com/gp/product/B00LF10...
You will also need to purchase the right 3.5" to 2.5" SSD bay
http://www.amazon.com/gp/product/B00G56Z...
Armed with a full suite of tools that I purchased from iFixit the whole job didn't take very long at all.
Just follow the instructions for replacing the HDD and installing the screen adhesive that's provided on the iFixit website and you'll be good to go.
The performance of your iMac will absolutely amaze you!
Счет 2
3 Комментариев:
There's a few issues here that you do need to be aware of: First your cooling system is now not working correctly! You'll need to install this part from OWC: In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later to do it right! Don't use software override, it will kill your system! Second point here: You didn't leverage the M.2 SSD port the system has, you just swapped out your HD for a SSD which is OK. Its just not what most people want, they want both drives active (Fusion Drive setup).
из
I replaced a 1TB HDD with a 1TB SSD without the In-Line Digital Thermal Sensor & used software to "control" the fan and about 4 months later the power supply board failed. I've opened it up & it looks like one of the small chips has blown and the whole supply board needs replacing. I have now ordered an in-line sensor & will uninstall the software.
из
Sorry for the bad luck. Thanks for sharing! Hopefully others learn from your experience.
из
Добавьте свой ответ
petitglobetrotteur буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 8
За последние 30 дней: 20
За всё время: 30,945
