iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467вопросов Показать все
Upgrade Core 2 Duo 3.06 GHz to a newer I Series CPU?
Hi, I've a 4 year old iMac with a 3,06 GHz Core 2 Duo processor. I would like to know if it's possible to upgrade it to a better one like a i3, i5 or i7. Has anybody done this upgrade?
Thank you
Dario
Это хороший вопрос?
Оценка 5
Добавить комментарий
4 Ответов
Наиболее полезный ответ
There is no possible upgrade path here, sorry ;-{
Intel never offered a pin compatible LGA775 socket i3, i5 or i7 series chip. The systems architecture is very different.
The only option which I think is going overboard here is to swap out the logic board with the iMac 27" 2.8 GHz i7 (Late 2009) logic board. Given the amount of work and price of a new logic board, I think you would be better off with a newer used system for the price.
Был ли этот ответ полезен?
Оценка 4
I found this same problem on an older post from IFIXIT, looks like they were asking about the same model. Here is the link to the problem, in the answer Mayer posted a link to a guide on how this can be done: iMac27 dual core 3.06 2309 CPU upgrade
Hope this helps
Оценка 0
If you purchased i5 or i7 logic board for the same model, you could upgrade the iMac to i series.
Оценка 0
Rundown of the different CPU's and there sockets:
  • Core 2 Duo & Core 2 Duo Extreme (quad) - Socket: 755
  • i3 & i5 1st gen - Socket: LGA1156
  • i3 i5 2nd & 3rd gen Socket: LGA1155
  • i7 1st gen Socket: LGA1366
  • i7 Extreme Socket: LGA1366
Оценка -1
1 Комментарий:
You have some errors here. I would recommend referencing this site:
- Intel Core i3 processor families
- Intel Core i5 processor families
- Intel Core i7 processor families
As a better reference
из
Добавьте свой ответ
Dario будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 44
За всё время: 15,710
