The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
x on the signal bar with any sim card
with original sim card or any other sim card there is an x on the signal bar, so i am presuming that the signal receiver is broken. i have opened up the backberry and im looking at the chasis or the motherboard. Where is the signal receiver and what does it look like?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Couple of things:
First, I read your previous question and I'm not convinced it is an antenna fault. However, to answer your question the antenna looks like this and costs about $2.00.
Second, I believe, if it is a hardware issue, that it may be the SIM card reader itself. If that is the case you may need a new logic board.
Third, the little "x" in the signal area usually means that it is still actively searching for a signal, but is not in range of one. So it is possible that since you were changing settings for unlocking the phone that it is searching for a signal that is is out of range of. If this is the case it means your hardware is all perfectly fine and you have a software (settings) issue.
Был ли этот ответ полезен?
Счет 1
hello i have cell phone blackberry curve 8520 icant type keyboard thank you.
Счет 0
Добавьте свой ответ
kayleigh буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 634
