The airbag light just came on and won't go off. Help!
I think the question covers this pretty well. The airbag light came on and occasionally goes off for a second or two, but then comes on again. I haven't seen a reason it might go off. Is there an easy fix for this and what does it mean?
Это хороший вопрос?
4 Комментариев
I have the same pronlem
из Donna
Hi, I am not expert but I would like you to suggest something. f you car model is in the recall list try calling the car show room or the company service center. If not The airbag light problem I think you might have to go to the service center and get it fixed and I am guessing it should be just a small software error (but might not be cheap).
Or
There can be fault in the wiring. Either ways if your car is still in warranty you may get it fixed.
You can try to check of there is an error in the system by using OBD - II Bluetooth dongle but you still have to go to the service center to fix that error.
Every time you try to start the car please wait till all the lights except for the parking (!) and battery are gone and the start the car. This way there will be less chances that the on board computer in the car has no error or system failures.
Cheers
из Suneel Seethamraju
Is any recall for a Kia Sorento 2010 static airbag light applicable to Kia’s sold in UK, or only USA. My Kia Dealership is not ‘aware’ of it>
из Patricia Lynn-Macrae
I've tried to do an internet search on the information given above re 2010 Kia Sorento recall on airbag light switches but cannot find it. Are such recalls published in one data set for all countries?
