Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832вопросов Показать все
I want to pull data off the hard drive I removed
I have removed the 20 GIG Hard drive from my PowerBook. I want very much to copy the files off of it onto my MacBook Pro.
What would I need to purchase to connect that 50 pin drive to some USB port and mount it ?
Michaelejahn@gmail.com
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Выбранное решение
Hi Gabe,
thank you so very much for trying to help me related to my problem reading data off of my Hard Drive that i removed from a dead Apple iBook.
you replied with a link to a product we already own (thanks for the reply !)
http://www.google.com/products/catalog?q...
unfortunately - that device has only 20 rows / pins max, and the drive that I have has 25 rows / pins
picture here;
click here to link to a picture of the hard drive on google picasa
any ideas ?
Michael Jahn
Application Support Specialist
Compose Systems Inc, USA.
4740 Northgate Blvd. Suite 100
Sacramento, CA 95834
Tel: (916) 920-3838 ext 102
Fax: (916) 923-6776
Email: michaelejahn@composeusa.com
Web:www.composeusa.com
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
You probably shouldn't put all your information down, as that post is public on the internet - anyone can see it.
из
You accepted your own answer.
из
Наиболее полезный ответ
will connect SATA, IDE (3.5" and 2.5") all to USB
Оценка 5
2 Комментариев:
That will work. +
из
Hi Adam - I have been on the internet before there was one. Everyone knows my contact details. but thanks.
из
The device you have should have 22 rows for 44 pins and the 2.5 HD has 25 rows but you don't need to plug the 3 last rows. The last 4 pins are needed when connecting jumpers on the drive.
Оценка 4
1 Комментарий:
that worked like a CHARM !
the 22 pin connector worked great - like you said, the two other pins were not needed.
THANKS !
из
Добавьте свой ответ
Michael Jahn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,867
