Вопрос закрыт
this computer can only take 3GB max.
I ordered 2x2GB sticks before I knew better, only to discover that this computer can only take 3GB max. Fortunately, I was able to return one of them and kept one of the original 1GB sticks in the other slot, for a total of 3GB (which works fine).
Это хороший вопрос?
Оценка 0
4 Комментариев
What do you mean by "interleaf" when using two 2GB sticks?
из
Maybe this will help explain Wiikipedia - Interleaved Memory
из
Thanks for the link. Do the two sticks have to be the same brand for it to work, or just the same capacity?
из
You want a matched pair (same brand & series)
из
Добавить комментарий
1 ответ
Выбранное решение
Your system can support both 2GB sticks, yes it will only use the 3GB. But that 1GB loss offers interleaf were as using the one 1GB & one 2GB sticks loose that. Don't forget to update your EFI firmware.
Был ли этот ответ полезен?
Оценка 1
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 143
