The 2013 edition of the Kindle Fire HD 7" tablet by Amazon. A budget edition of the new Kindle line, with a lower screen resolution than the HDX, and lacking the 2012's camera. Released October 2, 2013.
36вопросов Показать все
Kindle fire shattered screen repair
our kindle fire has a shattered screen. It still works well but the glass is shattered and we need to know which part to order and how to replace it.
Это хороший вопрос?
Оценка 8
5 Комментариев
I have the Kindle model sq46cw with cracked glass, but it works.
из
kburnsrdh, what are you looking for?
из
i am looking to replace the cracked glass, but not sure what part to even put in for a search. Everything works on my son's Kindle model sq46cw, but it is annoying to look through the cracks. I know I can buy a new one for $99, but it seems like a waste and I don't want to spend too much if they are so cheap. That's why I would like to try replacing just the glass cover if possible.
из
I am a child i cant but anything without my parents permission, and they will never let me buy anything of the internet nor pay to fix it. So is there a way to do it manualy? My screen cracked, half of the screen works but my computer is on screen lock so i cant put my password because half of the screen doesn't work. Please help!!
из
I have a cracked screen and I don't know how to fix it
из
Добавить комментарий
5 Ответов
Выбранное решение
In regard to the repair, have a look here
Kindle Fire HD 2013 Teardown
Probably the best you'll get for a guide at the moment
in regard to a screen, you'll need to hunt eBay, pretty much the only way to get kindle parts is from pre-used kindles. The problem is the age. you need to find someone who has a broken kindle but a working screen they can sell. because these are all still under warranty. if an internal part fails Amazon will replace it.
You can set up an eBay search for the part and in advanced search you can set eBay to email you new results as they come in every day.
Был ли этот ответ полезен?
Оценка 1
If you are able to use it with no color lines or whiteouts, then the only thing that might need to be replaced is the LCD display glass. you can get it on eBay for anywhere from $30 to $45. If you are spending over $70 on the display, you are purchasing the digitizer as well, which you probably don't need…. unless you break it while replacing the glass, which is easy to do.
If you aren't very handy at small item repairs (some of the pieces might be so small that tweezers and magnifying glasses would be useful), then go with the complete display replacement (including digitizer).
Either that or you could have your neighborhood "geek" fix it for you and pay her/him a small fee plus parts. I bet it would be easy to find a techy that would do it for $75 or less… including parts! That's what I would charge.
Оценка 0
There are two types of digitizers for the kindle fire. Here are the two options. Which one do you have?
Kindle Fire Flex A
Kindle Fire Flex B
Оценка 0
Оценка 0
My kindle screen is cracked. It won't allow me to type anything. What should I do?
Оценка 0
Добавьте свой ответ
brenda будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 12
За всё время: 23,588
