Samsung Galaxy Nexus является частью линейки флагманских устройств Nexus от Google. Он оснащен скругленным HD-дисплеем Super AMOLED и работает на ОС Android версии 4.0 Ice Cream Sandwich.
How to fix broken screen myself?
I dropped my Verizon Galaxy Nexus (SCH-i515) and the screen's outer glass broke. The display itself and the digitizer (touch sensor) seem to work just fine. Is there a DIY method of replacing the broken glass? I've seen the part (the glass front panel) online for anywhere from $15 to $25, but I've also read that the glass and the digitizer are somehow glued together such that it's necessary to replace the whole display (around $150-200!).
Any advice/links/tips would be most appreciated, including a list of needed tools to get this done. I'd just buy a new phone, but I still have a year left on my contract!
Thanks!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Chris, check the teardown on here. It will give you a basic idea about what you are up against. It will also show you the tools needed. Here is also a decent video. Yes, the screen is a display assembly and I suggest to replace the assembly, even so you can probably purchase the individual parts, but they are extremely difficult to separate. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Chris буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 21
За все время: 3,173
