Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
1158вопросов Показать все
Вопрос закрыт
Identify part that fell out when repairing
After following the step by step instructions on replacing broken glass a small silver piece and circular part fell out. It has the letters h-f on it. Can you tell me what this is and where they belong?
It fell out right after step 6. when I disconnected ribbons 1,2,3. and removed the glass from the mother board.
A larger view of the part.
Это хороший вопрос?
Оценка 0
1 Комментарий
Post an image of your part with your question. It will make it a lot easier to identify.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hello! It is the "MIC" of iPhone 3G. Show u as below pictures.
It belongs to complete dock assembly replacement. So I think you need to replace this spare part.
Here is the replacement part , http://bit.ly/1bLJiwc . You can know more at this website.
Hope will help you.
Был ли этот ответ полезен?
Оценка 1
can you make the picture bigger?
Оценка 0
2 Комментариев:
also you didnt mention at whatpoint it fell out
из
I cant find a place for it either, could it have come from somewhere on the broken glass screen? I would try finishing the repair as normal and seeing if it works then troubleshoot it from there. If it turns on, check all the settings and buttons and make sure they are working.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 91
