15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
58вопросов Показать все
Boots but white screen
Boots up and display on a external monitor. Laptop screen is completely white. Installed new screen and same thing.
Это хороший вопрос?
Оценка 4
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Jim Teel, this is usually caused by your backlight working, but not receiving any data. This could be an error on your LVDS connector as well as your LVDS cable, your LCD panel or even your motherboard. I suggest that you run the built in LCD test as described on hereAlso, try an external monitor and see what you get on that one during start up. this may provide further clues about any potential damage. Let us know what you find out so we can be of more help.
Был ли этот ответ полезен?
Оценка 2
pls follow the steps
1. turn off your laptop
2. press power button plus D plus + at the same time
3. wait for the normal screen it will go to normal
thats it have a bless day everyone
Оценка 2
4 Комментариев:
That also i tryed it not comming
из
Thanks, worked for us. -:)
из
Thank you for sharing. That worked! Now I can put the hard liquor back in the cabinet marked 'for emergencies'.
big hug xoxo
из
Mate I'm baffled it actually worried but screen is slightly washed out. But I'll let IT know
из
Добавьте свой ответ
Jim Teel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 16,224
