Originally released on January 22, 2005, the Mac mini is a small form-factor desktop computer made by Apple Inc. Currently, it is one of the four desktop models in the Macintosh lineup, and serves mainly as an alternative to the all-in-one iMac.
Superdrive HDD replacement not working
Hi
I've just worked through the guide to change my superdrive for an additional HDD. At the same time I also swapped the HDD for an SSD to boost speed.
Which ever drive sits in the original HDD bay seems to work perfectly (currently sending this via the SSD). However, the drive sitting in the superdrive replacement bay doesn't seem to come up on the desktop, or even be findable as far as I can tell.
I double checked that all of the connectors are snapped in (and they are as far as I can tell). Is there something I can do to find the other drive, or would it be possible that I need a new optical drive ribbon cable (or could to connector on the logic board possibly be an issue, in which case yikes!).
I don't know if the superdrive was working previously - I assume so as I bought the machine 2nd hand but in working order, specifically to swap it out.
Any help gratefully received.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hook up the superdrive and see if it works. If not then you have diagnosed your problem correctly and the cable needs to be replaced.
Был ли этот ответ полезен?
Счет 2
Thanks for this - I did just that and it worked perfectly. Turns out that the new drive wasn't engaged properly in the caddy. Thanks for your help.
Счет 0
Добавьте свой ответ
Josh G буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 257
