left trigger connector broke off logic board
Made a mistake trying to fix my psp go and made it worse, L trigger no longer works, any way to reattach connector to logic board?
Это хороший вопрос?
Это хороший вопрос?
aaron, the angle of the pictures is a bit distorting. It appears as if your solder pads are still in place. I would resolder the connector. You will need a good soldering iron with a small tip to accomplish that, but not impossible. If you are unsure on how to do it, any decent electronics shop should be able to fix that for you. Hope this helps, good luck.
Был ли этот ответ полезен?
The only way to fix it would be by soldering.
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 395
1 Комментарий
Thanks everyone for the help I really appreciate it, i am kind of new to all this and i apologize for being uninformative. You all were a great help! Thanks again!
из aaron
