The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797вопросов Показать все
replacing mini USB connector used to charge the device
I need to replace the Mini USB connector used to charge the device. Someone had tried to plug up a larger charger from another Kindel device and it damaged the USB connector. Seems to be too large to keep the charger cable connected to charge the device.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
jbooraem , here is a good video about the repair. The issues with that is the availability of the non-standard Micro B USB port. They are a bit costly, but available on ebay.com as well as a few other places.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
jbooraem будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 338
