The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73вопросов Показать все
How do I get my z10 out of this cattch 22?
I did a reset on my phone via bblink because my phone wasn't responding to touch for over a week. during the software reload I had no problem, but it seems during the last process my wifi got disconnected.
When the boot screen came on, I noticed a bright line of color came on from under the screen and kept coming up until it covered the whole screen and the phone didn't boot; So the screen is stuck at this point and I cant seem to do anything about it.
I tried to reload or reset the phone via bblink again but it keeps saying "the set-up process for this phone is uncompleted". I cant set up coz the phone is stuck and I cant reload or reset coz I cant set up. a catch 22 situation that's driving me against the walls. please help.
Это хороший вопрос?
Оценка -1
1 Комментарий:
Hello Michiel. Blackberry STL100-1. Thanks for replying. It does seem that issue has been resolved; I was advised by a friend to autoload the OS and I did that on Saturday; the phone booted fine and took me to the set up page. However, I'm still stuck because the screen is not responding to touch so I still cannot continue set up or do anything useful with the phone. This does mean that the screen issue is a hardware fault isn't it?
I should mention that some months ago my screen got broken and I had to replace it; I noticed that the issue with the touchscreen started after the replacement. Sometimes the screen would not respond to touch and I naturally assumed the tech person who assembled it may have omitted something. Do you think its a more serious issue?
из
Добавить комментарий
2 Ответов
What version of the Z10 do you have? You can find it under the battery (see here how to get it out: BlackBerry Z10 Teardown)
Был ли этот ответ полезен?
Оценка 0
You can simply solve the problem by replacing the touch digitizer only to see if the problem lies within that, or you can get to a service center and leave it to the experts!
Оценка 0
Добавьте свой ответ
fairy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 438
