Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
Вопросов 20 Показать все
Is there any differance between 2415 and 2560 lcd
My ıpad 2 (2560) lcd was broken.I changed the LCD, but I did not take any display on the screen except horizantal color lines.
Is there any differance between 2415 and 2560 LCD panels.May be I used to wrong one.
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
It's more likely that you didn't seat the cable correctly. Try reseating it. DON'T close up the screen until you test it and it works, as taking it apart is difficult and the more you do it the greater a chance that it will break.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
cem kutlu будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 482
