08.09.2015: Espon WP-450 - Phantom Paper Jam
This might be a bit different but today I had issue with phantom paper jam, only when I printed from Firefox. All files that were on the PC printed fine. So figured there had to be something up some where other than the printer..
So....I had loaded HTC phone software to my computer. This is the only think different from the day prior.
So I deleted the software and the drives through uninstall, but it did not remove the HTC file under C:\Program Files (x86) HTC (file has 6 folders in it) - so, I went to manually delte the HTC folder and could not do so. It still had something running, not could not be deleted.
So, went in and deleted one by one, till I was left with the file that was running: Internet Pass Through Service exe.
Went to task manager to shut down and denied access thinking if I shut it there I could delete it.
So approached it through Services (tab in lower right corner of task manager)
Services opens up, scroll down until you find the Internet Pass Through Service (name might not contain all words, but you will see it)
Right click on it and stop it.
Then go back and delete the file.
Problem solved, printer now works fine.
Hope that helps anyone else with this type of issue.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
68 Комментариев
I have the w3540 it kept saying paperjam but no paper present in it.took all ink cartridges out and place in working now..thanks
из ladyportier99
Folks, There's a good lesson to be learned here; never pull the paper out from a jam in the opposite direction. Always pull a paper jam out in the direction the paper path is taking it.
из Nathaniel Miller
Latest Artisan 837 paper jam and error message caused by the iPhone iOS 9.0.2 update. Printing from phone caused a lengthy grinding sound then the paper jam/wrong paper size error message. After which I was unable to print from any source. After several hours on tech support and another hour researching new printers per the recommendation of the Epson rep, I reset again and tried printing from my computer. It worked until I tried again from my iPhone. After the iPhone error message, I was again unable to print from any source. So the glitch, this time, clearly is Apple related.
из ddlloyd
I have an epson wf 5690. It reports a paper jam every time the paper runs out. When I add more paper the trouble does not clear and there is never paper jammed in the machine. I have to turn off and turn on the printer to get it going again. Not what I would expect.
из rswillner
I have an epson l355 It reports a paper jam every time the paper runs out. When I add more paper the trouble does not clear and there is never paper jammed in the machine. I have to turn off and turn on the printer to get it going again. Not what I would expect.
из abhay MISHRA
Показать 63 больше комментариев
