Why does my Kenmore 110 22062604 run, but not heat?
My dryer is running well, but won't heat and the clothes is taking forever to dry. Some internet research seems to suggest the thermistor is out and there are simple videos on how to replace it. Is this something I should attempt to fix on my own? Please help. We are broke and it would be nice to save on this repair.
Это хороший вопрос?
3 Комментариев
Julie, yes it does sound like something you can repair yourself. You have to be a bit handy, but it should be doable. I would like to give you some more information, but your model number does not bring up any information. If you can, please double check that number and also give as much information as you can about model etc.
из oldturkey03
Is there no heat or just a little heat?
из mayer
Unless we have the proper model number, we will all just have to guess. It could be the element, the two thermostats on the heater housing as well as the heat switch. Plenty of options of what could be wrong.....
из oldturkey03
