The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
My car is losing power and killing my battery?
I need fuse box diagram to troubleshoot my connections so, I could see the fuse inputs in my 93 Honda Accord SE. I got a fuse box diagram for 93 Honda Accord but it is different from mine. Please help I'd appreciate it. Thank you
Это хороший вопрос?
Счет 0
1 Комментарий
Is this closer to the fusebox in your car? http://i6.photobucket.com/albums/y205/pr...
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Its your alternator is bad
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Two places to start. First get a volt meter and measure voltage of battery, then start car and measure again.
Running voltage should be 13+, battery itself 12.8 or more. A car this age will likely start on a dying battery (under 12.2ish) but should stay running if alternator is charging.
Second- go to any auto parts store and they will run a quick check for free. This should answer most any other questions.
It is possible that you have a bad relay but unlikely. These can often be tested by swapping a light (pop up headlights?) or AC relay to the charging slot.
из
Добавьте свой ответ
jsandoval7988 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 259
