Repair information and guides for MacBook Pro models with 13" displays.
9743вопросов Показать все
Hinges have gone bad.
I believe my hinges have gone bad on my MacBook Pro. The display will occasionally flash and then look like stage lights shining up on the screen. Any suggestions on what I should do and can I fix it through items on ifixit?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
You need to obtain the recommended tools for opening the machine (every job is easier when you use the proper tools), Follow the guide to open the machine so you can tighten the screws on the clutches (Mac speak for hinges).
Before tightening back them out a bit and put a single drop of Loctite™ on the threads.
If this answer is acceptable please remember to return and mark it.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
What about the display flaking out on me? Will tightening these screws help with that as well or is something else needed?
из
Check the condition and connector on the LVDS cable… I think the extra play is shorting your connection and once you get the slack out of it you should be OK - unless the slack has allowed the cable to be cut/nicked. If you see cuts nicks you could try using some silicone to seal the short. I wouldn't loctite the threads until I knew I didn't have to go back in and replace the LVDS cable.
из
Добавьте свой ответ
benandem98 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 211
