Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
36вопросов Показать все
Thinks there is an external monitor attached.
I inherited an iBook G3 14" (700Mhz) and installed Tiger and updated to 10.4.11. Now, every so often like the fabled dripping water torture, the screen goes blue for a couple of seconds as it does on my MacBook Pro when I attach it to a projector. Also, when I click on the menu bar "Displays" icon, there is a ghost VGA monitor with resolution settings showing up alongside (well, under) my Color LCD's settings.
I've just tried attaching the Apple VGA adapter a few minutes ago to see if that would stop the switching and so far, so good but I'm not exactly hopeful. Has anyone else had this problem? Any fix other than what I hope will work with attaching the adapter?
(btw, the adapter is not attached to any other cable or monitor)
Help...
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
It might be a good idea to take a look at the display, and check if anything is loose or disconnected. You may also want to try with an external monitor and see if this problem persists.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Christopher будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,005
