The screen doesnt work
The screen of my iPod doesn't work, i try to turn it off, or turn it on and it dowsn't work when i connect the iPod to the pc, the pc recognize the iPod touch but the screen is still black, i can't listen to music the last time it worked normally i was listening to music and then it suddenly stopped when i tried to see what was happening the iPod screen was black... :( i don't think it turned off because of the battery, when i was listening to musci i remember that the battery was in 50%
sorry for my english :(
help please i'm desesperated because i'm in bolivia and there's nnowhere i can go to get the iPod fixed, i bought it in france 6 months ago...
thanks
Это хороший вопрос?
Счет 1
4 Комментариев
The iPod charge when i connect it to the computer... i tried to reset the iPod and it doesn't work...
из
does in itunes everything look normal ?
из
yes in itunes looks normal
из
did you try to make a screenshot ?
(press and hold the power button and then press the home button - this should work with firmware 2.x to 3.x - you should hear a shutter noise and after that, connect it to the computer and look inside the dcim folder of the iPod)
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
does itunes report any problem or will it connect normal ?
does the iPod charge when you connect it to a computer ?
maybe you should backup your stuff and try to make a hard reset (press and hold the Sleep/Wake button and the Home button for at least 10 seconds - then the iPod reboots) if that won't help - restore it with itunes.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
tim буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 2,314
