1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139вопросов Показать все
Where are the power-on pads?
Hi there, I have a Macbook Air mid 2012 - 11 inches model - a1465, I drop a beer on it and after a couple days still won't turn on.
I've unmount everything and let it dry for a week. Now I want to power on but the keyboard doesn't work, if I connect the charger the light stay grey... Maybe the battery is charged so I want to try using a little cable for make a bridge and turn it on but I don't know where are the pads on the ELEVEN inches.
I saw in this great site a lot of picture but they describe just the old models or the 13"..
Please help me!
Update
any help?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
You'll find that on more recent models they stopped with the pads - from the ribbon cable connector block you have to '''short short pin 5 to pin 29 or ground'''.
Clean the logic board before attempting to start (you can do more damage force starting like this).
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I've tried but nothing happen. With a multimeter I've checked that the I/O board take the electricity and transfer it to the logicboard with the black cable but the charger (that works) keep the led grey. There's a way to check in which part the electricity stops?
There's a way to check if the keyboard works? Maybe my mac needs just a SMC reset... How can I reset it without the keyboard?
Please help me
из
Добавьте свой ответ
Ade будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 2,100
