Display Problem : Green on black color parts on screen
Hi
I have a problem here, anyone can help ? :p
Everything that's black on the screen displays green 'matrix' color.
It happens whether it's using integrated intel card or the dedicated nvidia.
By squeezing / moving the body of the computer the problem can disappear....
Looks like a faulty contact somewhere, i opened it and it seems the problem stops when i push around the right heatsink
I found some stuff around on the web and it seems it's a know probleme but nobody really seems to know what it is, ever heard about this ?
Thanks a lot
Это хороший вопрос?
10 Комментариев
I have same problem....any fix's available ?? Thanks
из Damien Crowe
Hi def
same problem here in venice, italy :-(
10 days ago my MacBook Pro mid 2010 started to show acid-green instead of pure black.
Have you found any solution?
I changed my main board just 4 months ago and laboratory gave me just 3 moths warranty.
Thank you
Maurizio
из maurizio celant
Did changing the main board take the problem away Maurizio?
из Damien Crowe
Same problem here (Venice too!). I have heard that there is a cable replacement available from a China distributor, has anyone tried it? Or any alternative to solve the problem?
из Pierpaolo De Gobbi
I´m in Malaga - Spain and i´m having the same problem. I have connected to the HDMI output and working ok ! but if i use minidisplay port to DVI adapter I got the green lines (matrix style) on the dark areas.
из Sebastian Bugia
Показать 5 больше комментариев
