Repair guides for smartphones manufactured by LG that use the Android operating system (OS).
Why phone suddenly shut down and I cannot open it again
My phone (LG-P768) suddenly shut down and i can't turn it on it didn't fell down nothing bad happen it just turn off automatically i check the battery with the same mobile and it's working.
Это хороший вопрос?
Счет 20
8 Комментариев
My phone is LG G2. Around 9pm awhile ago, I used it for around 5 minutes. Then around 11pm, I was about to check the time but it was already turned off and was not responding when I tried to turn it on. Please help me.
P.S.: I'd really appreciate it.
из
My LG harmony 2 doesn't want to turn on and it was fully charge and it didn't felt or anything bad happen. Why do I do
из
Bakit nag aotomatic shudown ung LG magna ko?? Mga 5mins ko ginagamit tapos magturnoff sya and then open agad..please answer may question..thanks po
из
My phone (4 mobile) suddenly shut down and i can't turn it on it didn't fell down nothing bad happen it just turn off automatically i check the battery with the same mobile and it's working.
из
my phone is Huawei y7 prime 2019 it suddenly shut down itself and I cant open it's back and see the battery co'z it wont open and I cant open my phone too. can somebody help me ? what do I need to do to open it again?
pleassee.help me
из
Показать ещё 3 комментариев
Добавить комментарий
4 Ответов
Наиболее полезный ответ
grace, try to remove the battery for a while, then reinsert it. If that does not help you may have to perform a hard reset. Performing a hard reset removes all data including the Google account, system data, app data, app settings, and downloaded apps. Only perform a hard reset if absolutely necessary. Pictures, videos and music are also removed.
  • Ensure the device is powered down.
  • Press and hold the volume down button then press the power button.
  • Note When the 'Permanently Erase' screen appears, release the buttons.
  • Press the Power button to perform the reset.
  • Press the power button again to confirm.
  • Note This boot process takes several moments, reference the progress bar located in the upper-right. If the device hangs or freezes, remove/replace the battery." from here. Hope this helps, good luck
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
what if you cannot take out the battery
из
With checking on another site - the advise was to hold the on button AND the volume down together for two mins - guess what - it worked!!
Счет 3
2 Комментариев:
my phone suddenley shut then open shut then open and its 100 help please
из
Thank you so much for posting this!! My phone started working again!!
из
Try putting your phone on charger and open it, it's a temporary solution.
Счет 2
Try a factory reset. Assuming the phone is off, hold down power and volume down. When the LG logo flashes, release. Press power twice to confirm.
Счет 1
Добавьте свой ответ
grace буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 27
За всё время: 29,577
