Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
My screen does not work after replacing superdrive
I have an iMac 21.5, EMC 2389 model. After replacing the Superdrive with a SSD I have damaged the monitor data cable (APPLE P / N 593-1280 VENDOR: ACON) and has come out a cable wire vertical sync LED card (APN: 593-1237 REV : A VENDOR: LW). The case is now unbootable iMac screen after being turned off, however if it boots the screen when I restart the iMac. Know if these symptoms may be normal for educated the monitor data cable?, Where I can buy these cables?
Thanks for your help and sorry for my English by google traslator.
Это хороший вопрос?
Счет 4
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Go here to find your part number: http://www.welovemacs.com/mc508lla.html
Click on the box to the left of this to blow it up: Apple iMac 21.5-inch 3.06GHz Intel Core i3 (MC508LL/A) Parts & Upgrades
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
ok thank you very much.
из
I believe that the cable that you need is this one. Double check your model number before ordering.
Счет 0
1 Комментарий:
Thank you for your help.
I am not sure that this is the cable that you indicate. I think the smart thing is to bring the iMac repair center.
из
This is the cable you need.
http://www.ebay.com/itm/New-LCD-Cable-59...
Счет 0
Добавьте свой ответ
Joan Recasens буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 1,896
