Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330вопросов Показать все
Can I install an SSD on a base system?
I have read that these models use the same blade SSD as a retina MBP. Can anyone verify that all the necessary components are inside a base model i5 Late 2012 iMac? I want to get one of these (from eBay or somewhere), but I do not know if any hardware components will be missing (like the sata connectors are missing on the new Airport Extreme, but not on the Airport with TimeCapsule).
Update (02/10/2014)
Thanks for all the info and lively debate. I think I might have confused the question by using the term "sata connector". I was not completely sure what type of connector the blade SSD use (sata vs msata vs half mini PCIe... they get so confusing).
So. Can we definitively say the iMac Intel 27" EMC 2546 does not have the proper internal components for installing a *blade* SSD myself? If not, is this something I can also get aftermarket, or will it require a skill in soldering I dare not even think about? ;)
There are a few sites where people suggest conflicting data (here is one):
http://forums.macrumors.com/showthread.p...
These are also pretty exhaustive specs on the model:
http://www.everymac.com/systems/apple/im...
In particular, I was hoping to get personal verification of this quote:
For storage upgrades, if the 21.5-Inch "Late 2012" iMac models were not configured with an SSD or a "Fusion Drive" at the time of purchase, there is no way to add a PCIe-based "blade" SSD later as the needed connector is not present. However, the 27-Inch "Late 2012" and all "Late 2013" iMac models do have this connector on the motherboard even without a pre-installed SSD, so it is possible to add a PCIe-based "blade" SSD after the purchase of the system.
Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
If the EMC 2546 is definitely the iMac you have then according to Everymac you definitely have the PCI port to put an SSD. Everymac says the 2546 is the late 2012. It also says every late 2012 27" has the PCI port for the SSD. Here is the exact quote and the link.
Link here. Look in the section called "internal differences"
Link to your iMac
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I think I will trust everymac.com in their assertion that my computer has the connector. Now, I need to identify the part to order. Is this the correct one?
MacBook Pro 15" Retina (Mid 2012-Early 2013) SSD
из
Here's the answer Fussion drive - connectors?
Оценка 1
Добавьте свой ответ
Adrian De La Mora будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 9
За всё время: 1,989
