Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64вопросов Показать все
Can the USB 1.1 be changed to the 2.0?
I have 4. 2 ea. 366 & 466.
Thought it may help.
Will the firewire duplicate some of the
USB functions, maybe faster.
Thank you, Leland
Это хороший вопрос?
Оценка 2
Добавить комментарий
6 Ответов
Выбранное решение
No. There are no logic board upgrades for the Clamshell that have USB 2.0.
Был ли этот ответ полезен?
Оценка 5
1 Комментарий:
Agreed +
из
"In order of speed (lowest first)
USB 1.0 -> USB 1.1 -> FW400 -> USB 2.0 -> FW800"
Not really.
For all practical intents and purposes, FW400 is MUCH faster than USB 2.0, and even faster than USB 3.0 in many instances.
Оценка 1
This Firewire is FW400 which runs at 400Mbps rather than USB 1.1 which runs at 12Mbps.
If you are connecting an external drive, make sure it has a FW connector.
The hardware does not support USB 2.0. Add a USB 2.0 external hub and it still runs at USB 1.1 at the iBook connector.
1Mbps -> 12Mbps -> 400Mbps -> 480Mbps -> 800Mbps
But in the best tradition of all of these standards, YMMV.
Оценка 0
Mark,
I guess my point was that FW400 is faster than USB1.1.
I have Macs with USB1.1 and FW ports and I use FW drives. I couldn't be annoyed with the slow speeds of USB1.1.
Оценка 0
No, you will need to upgrade your logic board to change it to FireWire.
Оценка 0
ขอบคุณข้อมูลของคุณหัวข้อนี้ช่วยฉันมากเกินไปสำหรับการแก้ปัญหา
ยินดีต้อนรับสู่
<br /> <a href="http://batman999.com/"> สล็อตออนไลน์บนมือถือ </a> <br /> <br />
Оценка 0
Добавьте свой ответ
Leland Lang будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 2,677
