Can I install a GPS antenna on Ipad Mini WiFi Only?
Can I install a GPS antenna on the iPad Mini WiFi only with these steps?
iPad Mini Wi-Fi GPS Antenna Replacement
thanks
Это хороший вопрос?
thanks
Это хороший вопрос?
Nope!
Apple has different logic boards for the WiFi only Vs the cellular/WiFi units. The needed chips are not on the WiFi only model.
Был ли этот ответ полезен?
You can add an external GPS, like the ones from Bad Elf.
Are you still able to find them??
I’m no expert on the subject, and I am here because I was pondering the procedure as well. Dan’s response leads me to another question. If you were to procure a “for parts only” iPad mini of the same generation and transfer from it, the gps antenna and logic board, would that circumvent the roadblock? I think it would be possible as long as the hardware wasn’t iCloud locked. But again, this is merely a presumption of mine.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,347
1 Комментарий
Yes, you cannot directly install a GPS antenna on an iPad Mini WiFi-only model as it lacks the necessary hardware to support GPS functionality. GPS is available only on the cellular models of iPads, which come with built-in GPS hardware.
из Antor
