Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
Why is the replacement battery connector different from the oem?
Why is this battery connector different? Did you send me the wrong one? It's supposed to be for an iphone4s.
The old battery is 3.7v=5.3Whr
and the one you sent me is 3.7v=5.25Whr
old vpn is LIS1474APPC
new vpn is P11G97-02-s01 WHY DID IFIXIT SEND ME THE WRONG BATTERY!!!!
But the real problem is that the new one has a smaller plug plate and missing a mounting screw hole Arrggggh!
Это хороший вопрос?
Оценка 1
3 Комментариев
I ordered a rep i4s battery replacement kit and had the same issue. Obviously there was a design rev and someone forgot to notify parts suppliers. It may also be that they're trying to dump old inventory on the unsuspecting.
из
I got a replacement battery,they gave me the old one from my phone isVPN:LIS1474APPC ,,i am not sure they change it or just gave me just a used battery.????
из
Because its a Iphone4 battery and not a Iphone4s
из
Добавить комментарий
3 Ответов
Выбранное решение
The top battery is iPhone 4S, the lower iPhone 4. You are correct the iPhone 4S battery connector has two screw holes and the iPhone 4 only one. Surely a mixup.
Был ли этот ответ полезен?
Оценка 2
2 screws iPhone 4S
1 screw iphone 4
Оценка 0
your new battery is for Iphone 4 and your old is for Iphone 4S
Оценка 0
Добавьте свой ответ
ggil будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 985
