Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
Front facing camera freezes, not working!
Hi,
I keep reading the great solution for the iPhone 4 front facing camera issue after screen replacement, but nothing fo the 4S.
I did a screen replace on a 4S, switching also from white to black. Since then, the front facing camera just won't work. When I switch form the rear camera to the facetime one, i just get a blurred image from what was on the rear camera, but nothing active on the front facing camera.
I read about a small jumper that may have gone missing on the 4 version, but is there a similar jumper on the 4s that could have broken off? All the 4 version photographes are - of course- totally different from what I see on the 4s mobo. I already replaced the camera, but nothing still.
All help is greatly appreciated.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
The little jumper on the iPhone 4 when it goes you can't see the camera what so ever it would be stuck on camera shutter.. Was going to say change the camera but u have done that .. I would check u haven't damaged the pins on the motherboard
Был ли этот ответ полезен?
Оценка 1
I was wondering if there had been a solution to your dilemma. I too have the same issue with an iPhone 4s
Оценка 0
Nothing yet then has anyone got a solution for iPhone 4s front camera fix
Оценка 0
Добавьте свой ответ
Eva Tahon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 3,273
