Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106вопросов Показать все
Speaker sounds distorted at higher volumes
A few months after I bought my iPad, I noticed that at high volumes, sounds on the built-in speaker were distorted on all applications. It sounded like a blown speaker. I tried rebooting and restoring my iPad to no avail.
The interesting thing is that it only seems to be coming from the left channel.
I went to Settings>General>Accessibility>Hearing and was able to adjust balance.When I set the mixer to right only, the speaker sounds fine (but is only the right channel) It starts to sound distorted as I bring the left level up.
It sounds fine on headphones and bluetooth speakers, no distortion at all.
Any ideas for a permanent fix that allows me to listent to both channels at the same level?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
If its still under warranty take it to apple otherwise, it sounds like you may have to replace the speaker.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Out of warranty. Speaker sounds fine if balance set to the right.
из
The speaker is damaged, probably by overloading it. It's not worthwhile to open/wreck an iPad to repair just the speaker.
Оценка 1
Добавьте свой ответ
wresnik будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 26
За всё время: 7,564
